how much torque for head bolts?
Let me google that for you
LOL sorry I just had to, but to answer your question:
1. TORQUE ALL CENTER BOLTS TO 34 NM (25 FT LBS.), TORQUE THE 4 CORNER BOLTS TO 27 NM (20 FT LBS.).
2. TORQUE ALL CENTER BOLTS TO 68 NM (50 FT LBS.), TORQUE THE 4 CORNER BOLTS TO 47 NM (35 FT LBS.).
3. RE-TORQUE ALL CENTER BOLTS TO 68 NM (50 FT LBS.), TORQUE THE 4 CORNER BOLTS TO 47 NM (35 FT LBS.).
4. TIGHTEN ALL BOLTS IN THE SPECIFIED SEQUENCE AN ADDITIONAL 1/4 TURN.
Make sure you use the correct sequence. The center two bolts are 1&2, the ones to the right of them are 3&4, the pair to the left of center are 5&6, bounce to the other side, 7&8, etc, etc. Torque sequence is 1-10, in that pattern.
Hope this helps.
You will find that most people will tell you to search first because there are a TON of threads on these subjects made all the time.
