how much boost on stock turbo
geoffskiGTS
Aug 9, 2008
fayetteville, North Carolina
:confused:i just bought a 95 eclipse gst. i want to put a manual boost controller on it but not sure if its worth it or not. i have obx fmic,pacesetter tubo mani, 2.5" megan racing cat back, greddy type rs bov, dejon intake ( stock maf setup ). everything else is stock. turbo, intake mani, injectors and so on. so whats the safest ammount of boost i can push on stock turbo without upgrading the fuel delivery system and what brand of boost controller do u recommend. any input is useful, thaks a bunch. :confused:
The stock t25 cant handle more than 16 psi. Right now my car is running 15 psi on the stock turbo and all I have is an intake, fmic, greddy type-s bov, exhaust, turboxs mbc, and some gauges. So with the stock turbo and your mods you can run about 15 psi as well, just make sure that you get a boost gauge before you hook up the boost controller. As far a brand of boost controller, there are a ton of nice ones. Like I said earlier I have a TurboXs boost controller and I like it alot and have not had one problem with it. Also hallman makes good boost controllers as well. Good luck
The search button is your friend. This is topic has been beaten into submisson.
big time search but to answer your question with a stock fuel system no more then 14psi and thats pushing it
