how high to boost?
96tsiaddict
38
Dec 26, 2004
bellingham, Washington
All right so I've got a boost controller and aftermarket BOV on the way but how high am I looking at to boost as a max. Everything else is stock.
Maybe, Maybe, 16 psi but becareful because without the gauges to watch air/fuel ratio you could run it lean and smoke your pistons. so jus becareful, if I were you, I'd run about 15 psi. later -Matt
