How does a mbc work?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
I was actually wanting to know everyones theory . Please provide links! Also i would like to know what all kinds are availbe ? If you have pictures please post them . Also explian how you hooked yours up . Thanks i would really appreciate any help.:thumb: I have my ideas but im not sure every one agrees and i would like to be on the same page
Quick answer, there are a couple different types, ball & spring & bleeder valve. Basically they put a restriction in the line so that the wastegate actuator sees less pressure, therefore taking longer to open, giving you more boost. Proper way to hook it up is to take a pressure source from the compressor housing, j-pipe or lower ic pipe & run it to the mbc inlet, then run another line from the mbc outlet to the wg actuator.
He asked for theories, so here's mine.
Boost pressure source from one or the other, compressor housing, LICP, J-Pipe, into inlet on MBC.
Ball & Spring style:
Pressure source pushes against ball.
Spring holds ball down resisting pressure.
Pressure builds until spring can't hold pressure any longer.
Pressure flows thru MBC outlet to Wastegate Actuator and pushes Wastegate Flapper open.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
