how do you adjust the clutch
marsh63
517
Oct 15, 2007
richland, Washington
how do u adjust the clutch on a 1g talon tsi awd. it dosnt engage all the way so it grinds my gears sometimes. it has enought fluid.
There's a threaded rod you can adjust at the master cylinder above the pedal, but be extremely careful, no more than an eight of a turn at a time without driving and testing. Make real sure the clutch is engaging properly after you adjust it, otherwise you will be doing a clutch job real soon. If that dose'nt work, you may need to replace the clutch anyway. Grinding gears could also be caused by worn sychros in the transmission.
