how do u know if your turbo is bad
kidd_clutch
Jan 2, 2010
washington,
how do u know if your turbo is bad becouse my car wont let me go over 8 psi normaly wen u drive it feals like u push out air but wen i get the gas the air feals like its pushin back in stopin me to move:banghead:
Search boost leak for one and check for "turbo shaft play" as well if you are that concerned.
iam sorry guys my spellin bad but i do that ### its like my styl u get but this is the thing i just put a new gasket in so it wouldnt b any air cumin from the cracks between the headers and the turbo but how do u check for shaft play
Rule #5 posted above the reply box
Use proper spelling, grammar, and punctuation when posting in our Tech Forums - don't use texting/instant messaging lingo here. This isn't an English class, but we demand that you at least make an attempt or your posts will be deleted. Internet Explorer users should download IEspell or just use Firefox since it has spell check built-in.
Start spelling properly and using your shift key if you want any replys! Mods won't be as forgiving...
now i said sorry for the spelling but pleas dont disrespect me ok thanks but whats the boost leak test and checking the shaft play
the other trouble i have is taking off my pulys so i can get to my cam sensor when i try to screw it of the pulys move with it so screwing is point less
Here, I will spoon feed it to you:
Here comes the Airplane!
Boost leak test:
2G Turbo DSM Boost Leaks -How to test and fix
And for checking for turbo shaft play:
1. Remove the intake pipe from the Turbo
2. Stick you fingers in and grab the shaft
3. Wiggle it and feel how much it moves.
4. It should not move much, but there should be some play due to no oil on the bearings.
If it has excessive shaft play, 1/8" to 1/4" or more, you need to look for damaged fins and possibly remove and replace/rebuild the turbo.
Was that good?
