how do i wire a air/fuel gauge
TSIGuy510
129
Nov 13, 2008
El Dorado Hills, California
ive search around and wanted a little more info. so i just got a autometer air/fuel gauge and im trying to wire it. i know to somehow connect it the 02 sensor wire from back of the ecu but my question is how would i make that connection and also where would i connect the red and black (power) wires too? the 02 sensor wire from the gauge is purple btw dont know if that helps or not
If you're talking about the kind that hooks to the stock narrowband o2 sensor, don't even waste your time. They don't really give you any useful information.
honestly its gotta be better than nothing, i know its crap but i need a rough guide to tune my afc to make sure im not gonna blow up. i understand that its not gonna shout a number out at me but i figure as long as i can use it for a rough tune its gotta be better than not having one at all and tuning blind....
The red wire connects to a 12 V switched source, the black wire is your ground, and the purple wire will need to be tapped into the O2 sensor wire at the ecu. As others have said it will be of no use to you to tune with because it only reads a "narrow" band of voltage. So when the voltage in outside of the band the gauge will give you incorrect readings.
what does that meen in english? i dont under stand what narrow and wide band meens. hell i dont even know what band meens LOL
Maybe to show your o2 cycling in closed loop, all the gauge is going to do is swipe back and forth. When the car goes into open loop that gauge will peg out and hold. It is absolutely useless in tuning, but if you are set on having a gauge light show wire the purple wire to pin # 4. Red goes to a hot activated by the key, black is a ground.
1g ecu pinout:
1G ECU Pinouts
Narrowband is the o2 sensor these cars have stock. They don't give a real AFR reading, where the wideband can give you the actual AFR. The stock ECU uses the o2 at light loads to keep 14.7:1 AFR to keep the Environmental Protection Agency happy.
so does that meen i would have to switch the o2 sensor to a wideband type then?
Get a data logger for tuning, the gauge you are referring to will tell you nothing.
yah but that cost $ i dont have LOL the gauge was freee so i was hoping to put it to use but i guess not
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
