How Do I Install A BOV?
Eclipsing
170
Aug 4, 2002
Palatine, Illinois
Can you guys help me out? I just got a Greddy Type S Blow Of Valve for a 97 Gs-T. How do I install it?
If you have a turbo car, remove the black plastic thing that is clamped in th rubber pipe that runs from the top of the ic to the throttle body. Next, you need to install the bov adapter, which should have purchased seperatly, into the hole that you removed the stock bov from. Next, bolt the type s to the adapter, hook the vac line that you unhooked from the top of the stocker, to the top of the type s and leave the lower vac port unhooked. Reconnect the larger rubber hose to the big nipple on the bov and now you only need to adjust it. That is a totally different job so good luck.
If you dont have a turbo, you just wasted your $ on something you dont need and cant use.
Damn, I didnt know I needed an adapter. That sucks, thanks for the info.
