How Do I install 16g in 2G
cramec2
56
Sep 7, 2004
Manchester, Connecticut
I bought a EvoIII 16G today. Water coolant lines do not head the right angles.And the 2G install kit has an elbow for the turbo outlet that heads towards the air cleaner..Is there any how to's with pictures?
You can change the direction of the oil feed "elbow" as you call it by loosening the connection (at the base of it, near the turbo itself), directing the "elbow", holding that in place, and finally tightening the connection again. The coolant lines you will have to bend in order to angle them correctly.
This link has pictures and will help you out: http://www.vfaq.com/mods/2G-16G.html
