How can I be sure correct WB values are being logged?
Paintballaa5
535
272
Jan 23, 2012
Houston, Texas
I'm working on calibrating what the wideband logs in Link, and after tweaking the volts/lambda i've gotten it to read +/- .1 at idle. Its pretty darn close.
But I have a feeling its not quite the same when in open loop/ boosting. I cant drive, look at the computer, and the gauge at the same time, so how can I be sure it's logging the correct numbers?
I dont want to base the tune around the wrong AFR's and mess something up.
It's a AEM if that matters.
