Horrible MPG
dsmotors09
32
Sep 13, 2007
Topeka, Kansas
I am getting horrible MPG (10mpg), 1996 Talon TSI AWD, it smells like it's burning rich, but when I drive long distances on the interstate I get 24-25mpg. It's just the short distances that kills it I guess? Advice? :talon:
I recently bought NGK Iridium Spark Plugs to solve this problems, but it didn't make a difference. (Car just rolled 90,000)
Typically short distance trips (town driving) will get less gas mileage, but it shouldn't be that drastic of a difference. I would check for maybe any leaks dealing with the fuel system (around injectors and fuel pump) to see if you can find something.
How is it accelerating? Drive ability still alright?
BTW, those iridium plugs are probably already fouled, they are very sensitive and do not work well in most boosted applications(Including ours).
If you have already put those 550's on and they are untuned that might cause a little problem. Plus how many times do you boost when you take off from a stop sign/light? Do you have any smoke going out your exhaust?
Replace the o2 sensors. Get a new air filter...Exhaust...all these things help in gas mileage. I hear some pretty good things about people caming their cars and increasing the gas mileage.
Sorry, I havn't been on lately, I have noticed some white smoke when it's driving, but it's not too bad, sometimes the turbo lags which I don't understand since it's a T25, it's completely stock. When the car starts up you can hear the lifters? Knock. Idk if that has anything to do with anything.
I get horrible gas milage too but I have a bad O2 sensor. I had autozone check out why my check engine light was on and he said the O2 sensor. So hopefully when I change that I will get better gas milage
Check your turbo for shaft play. And ditch the iridium plugs. Swap them out for NGK BPR6ES. Do a boost leak test. Let us know how it goes.
I wasn't even throwing a cel, and just replacing it made my gas problem go away.
A note: while the shotgun approach to repairs and tuning can yield decent results, it is not economical, nor very bright.
