GSX_Dan
- 138
- 4
- Jun 27, 2004
Chicago,
Illinois
I'm going to be throwing in new Wiseco XX rings and I will be honing (de-glazing) the cylinder walls with a drill and a traditional surfacing hone with the 3 spring loaded stones. My question is if this finish that I will get will be fine enough? The tool says it uses 220 grit stones and there doesn't seem to be a choice to buy different ones.
Also if anyone has done this before at home do you have any tips as to how to get the best results? The Haynes manual just says to move the drill up and down and try to get a 60degree crosshatch finish. That doesn't sound like a lot of detail though. Any advice would be appreciated as to what speed to set the drill at and how many passes(up/down) are needed and how fast should I be going up/down? Also how much honing oil should I be using, or can some other type of oil be substituted? Thanks in advance.
), getting the whole cylinder. You'll get pretty steep angled crosshatches. I like to reverse the drill also and do it again, ensuring good coverage. You can use regular motor oil to do it. Make sure you clean out the cylinders after to get any metal shavings that are left.
