hole in the drive ??
ricerrocket
Feb 22, 2009
lincoln, Nebraska
i was slipping on ice then it caught concrete and like 5 mins later i here DINK and it downshifted, then about 5 mins after that it took like 5 sec 2 get into gear
I looked through your pictures and it seems you have an automatic? If there is a hole in your transmission, a lot of fluid would leak out.
And by final drive do you mean......torque converter?
Check your fluid level.
So you must have an auto because you mentioned it downshifting by itself. That's the transmission going into limp mode.
