Highest boost I can run?
I currently run 21 psi with my evo3 16g on my 98 spyder. stock headgasket.
Please dont just ask about "psi" alone. Tell use what turbo you are wanting to boost over 20 psi with. Chances are you may not be set up for that anyway. And if you want to go with just my answer ... this is what I suggest you do.
Your whp numbers are pretty decent. If you are not happy with those I suggest you take the head off the car , check everything out, and at the minimum get a metal head gasket, and some arp head studs torqued down to 85-90 foot pounds. ( stock is 73 or something like that, but your no longer stock now are ya ).
Guys have run 30psi on stock internals + stock HG. With 0 knock. Running that high of boost you better make sure the car isn't knocking. Things certainly won't last as long.
  • Wanted 6 bolt NT water pipe
    • chrisman287
