high Impedance Injectors?
whe3ls
910
5
Jun 23, 2008
spokane, Washington
so i have a non turbo. and i dont want to wire in the resistor pack. can i use high injectors?
Are you putting them in a DSM or your Hyundai?
DSM's are low Independence injectors. I would say no on the HIGH independence injectors if your putting them in a DSM.
The drivers in our ECU's are designed for High impedance injectors,hence why N/A's have no resistor pack
Low Impedance Injectors can only be used with an external resistor pack in our Ecu.On a turbo Dsm you would have to get another resistor pack(best option to make it easily reversible), cut the wires off at the resistors and solder them all together and plug it in. (which I'm guessing you know)
So Yes you can... .
