High Idle AGAIN
Venom1515
49
May 26, 2003
Orlando, Florida
Ok well it started with me having codes with the IAC and the IAT. When started the idle was going up to 4k+ so i replaced both sensors now no CEL but the idle is at 2k now, isn't that still a bit high for start up and what numbers should I look for?
Checked for vac leaks....gaskets...cruise control line.... egr line (if applied)....listen for hisses around the intake, common mistake when changing something on the TB. Make sure the iac/o-ring is properly seated!!!. 2k is a bit high, upon start up, it should reach 2500 rpms then depending on the coolant temp work its way down to 1100-800 rpms.
