HI trims good but low and mid not so good..1g
AL92
933
4
Dec 12, 2003
regina, SK, Canada
My car seem to be running pretty good but on my trims low trim is like 125 ,mid is also like 125 and high is like 104.They have had lots of time to stabalize.I know I can maybe get that idle trim down a bit more but don't think the base setting on my maft with new chip affects the mid trim.Should I even worry about the midtrim.this doesn't show any funny leaks does it.My vacuum is like 17 and I changed out the old throttle body seals.
Car seems to be running fine.I know it will correct for the trims if they are still withing range of correction so likley no big deal.Also when I start the car sometimes the idle will drop down and the car sounds like it will stall but rarely does and then idle comes up after a minute or so.Is this due to the 125 ltrim or should I maybe try tweaking the biss screw just a bit?
my low trim stays at 139...if i try to richen it up, it just get ass rich so i left it where its at...you might try to get the mid down a little more if you can tho and see how it runs...but if you arent knocking, i wouldnt worry about it
