hey stock 2G guys with pocketloggers
kr.k
215
Aug 9, 2002
what is your long time fuel trim readings? I had constantly about +8 - +10% readings and after finding my intake leak and fixing it it did not drop to 0 as I hoped but it is still around +3 - +6%. Is this the way it should be? If not what could be the problem?
thanks!
Yes, that is normal. Zero is the "ideal" number, but it rarely ever happens. That's why the ecu has the fuel trim values, so that it can adjust/self learn itself on where they need to be. Before I put my safc in my car, my ltft was like +4%. After the safc install, then I can adjust low settings to get it as close to zero as possible.
Fuel trims will vary on gas, weather, a ton of things. I would say as long as your + or - 5, then that's pretty good.
