420A hesitation after tb replacement
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
So I picked up this filthy rs for my gf. It had a high idle when I got it. I swapped the whole throttle body (including tps and IAC) with a clean one, seafoamed, changed pcv, plugs, wires, vc gasket, added fresh oil. Now I have the opposite problem. The car hesitates when I hit the gas. Also a decent amount of oil smoke. Possibly map sensor?
Retrace all you did, make sure all that seafaom is out check you plugs. Also check trottle cable adjustment might be too low of a position, clear all codes off parts you changed if still present.
