help with coilpack bracket
hondaslayer1
407
Nov 1, 2009
waukegan, Illinois
Have a problem that need to be figured out asap! I have a intake and coil that came off a rvr from japan. I have a bad coil and am trying to replace it with one from the original intake. problem is that i try to swap it and the holes dont line up.also the wires are in a different order too.Is there anyone that can help me out or give me a different idea how to make it work.:hmm:
if i get you correctly you are trying to put the coil bracket and coils that came off of the RVR in your eclipse? why not just pull the coils off the RVR bracket and put them on the eclipse bracket. the coils themselves should have the same bolt pattern. as long as you hook up the wires the same as you took them off you don't need to worry about the firing order, it will be the same. if it doesn't work that way post a pic so we can see what you are working with.
fixed the problem today.it was a bad coil on the jdm braket mounted to my jdm :hellyeah:out the power transistor while it was there. the problem was i was only getting spark on 2 and 3 so i swapped the coil out and the transistor. will try to start it later today hope it all goes well.
  • Wanted 6 bolt NT water pipe
    • chrisman287
