Help with an H1E
Prib9671
123
6
Jun 9, 2009
Rathdrum, Idaho
Anyone on HERE running an H1E? If so then what did you do for the oil return? I tried a billet flange with a -12an incorporated into it but it was way too large, it would hit my compressor housing v-band clamp/backplate before the holes lined up to bolt it on. You can forget about getting any female piece to bolt on because there is just not enough room. I would like to stick with a -12an setup to satisfy the Holset. I know I could get the stock cummins return and clamp on some hose, but I would like to use treaded fittings. Thanks
