help w/fuel pump install
RossY
627
Sep 27, 2002
Canton, Ohio
Ok so i finally tried to start my car and nothing. I come to find that i dont have a fuel pump, so i got a walbro 190lph. Looking at what i have it seems that there's something missing. Is the pump supposed to be bolted someway to the bracket? I noticed a small threaded hole on the bottom part of the bracket but i have no idea what was/is supposed to go there.
i also noticed that on the top of the pump it seems like there should be a spacer, o-ring and then a cap but the kit only came with an oring and a cap?
Where did you two get your pumps from? Did they include the installation kit for your respective vehicles? If not, you may need to purchase one.
yes it came with a kit. It had and o-ring, two caps the little filter, and a rubber boot like cover for the bottom of the fuel filter
thanks, that helps a lot. Now i know that im missing a spacer, and the bottom part of the bracket. Looks like im off to the junkyard tommorow.
