Help on IDing injectors
Ernie D
73
Aug 25, 2012
Westlake, Louisiana
I just bought some injectors on good faith that they were 880's and I'm having trouble IDing them, I wanted to see if anybody can help with this. Hopefully I didnt get the screwings put to me :pray:
The few things I did identify is telling me that they are GM injectors by the gm part # on top and the RP on the side but maybe somebody can shed some light on the subject. Thanks
more isnt an issue. less is. i would send them out and have them cleaned and flow tested before using them. 40 bucks to know they arent junk is good piece of mind
I agree with you on that, I dont think 40 or so more bucks will hurt to spend, I only have 50 bucks invested in them already. Do you recommend a decent place to get them cleaned and tested
when you have them cleaned and tested dont forget to have them replace the orings and seats
Those are the stock injectors from a LS1 right? I ask cause I have a part number of 17104988 which one website rates them at 72lbs/hr-765.7cc/min, and the other at 75lbs/hr-787.5cc/min. I also have a part number 17104959 which is 95lbs/hr-997.5cc/min. I'm not sure what these come on. Though the website says its the OE part number, but it lists no vehicle/engine, unless I read it wrong. Anyone have anymore info on these GM injectors?
