Help name the mystery part!
BlackbirdOfPrey
435
Dec 4, 2003
Shiloh,
I was hunting for boost leaks after I installed my new socketed EPROM, and I found one, but I don't know what part it is. My shop manual didn't show it, and none of the local parts stores knew it either (O'Reilly and Autozone). It is located immediately below the coolant temp sensor. It screws in and has two plastic vacuum nipples on it. The vacuum lines connect onto the top of the throttle body (to two of the 4 lines). One of the plastic nipples broke off.
It's the Thermo Valve.
  • Wanted 6 bolt NT water pipe
    • chrisman287
