Help me
Welcome aboard!
fuseboxcoverinside2g-jpg.66417
or how it sits in the car…
From: brake lights are out, fuses relays, checked, etc. WTF
That what it look like
Both cover pictures are the same. Just rotate it, all the fuses match up except the top right which should be a 10 instead of a 25. If someone put a 25 because the 10 was blowing I would look into that asap but it's only the anti theft so meh.
Ok so I pulled the fuses and put the correct ones in so it is the same as the pic but something not right with that because now my idle is revving up then dropping like the air control valve is messed up so all in all the car is running worse so idk
As this is the Intro / Welcome forum, I would encourage you to make another thread in the appropriate forum if you need further assistance. If you haven't done a boost leak test, that'd be a good start in tracking down an erratic idle.
This post has my interest.. Anthony mentioned that by changing fuses his idle curve has gone out of wack . How is this possible...
Its not LOL, the ecu has power or it doesn't and the isc is powered from the ecu, now I can see if he took a fuse out somewhere that is now stopping the car from charging where that might screw up the idle, but not if its charging fine which is the next thing he needs to check.
