Help me tune with logs, please
Well the problem with that is simple....no money! I goto college now and that leaves me with slim to none money left over for my car so just trying to do what i can, thanks.
only dsmlink shows knock on 2g's. That last log looked much better, but you didnt go to redline. I would say, fix the leak asap and do another pull to redline from about 3000rpm. Make sure you are at WOT the whole way.
spyderturbo007 said:
Remove abo0ut 3% across the high throttle map and make another pull. Also, add airflow to the parameters and see if you can get some more samples / second. :thumb:
Agreed, it looks like you are able to pull the car a little leaner :thumb: Also, I believe (if you are using tunerstein/palmnstein) there is a check box that you can have the sample rate a little faster. On my logger, I can pull 2-3 logs per 1k rpm.
mmcd gives the me the option of an ecu cycle of 100/110/115% is this the same thing?
