Help me name these parts
Cold Dark Shado
40
Sep 20, 2006
waseca, Minnesota
Thanks guys :)
1:
2:
The thing on the far right
3:
4:
5:
Ok, the 1st one I don't know. The 2nd ones is the lower part of the thermostat housing, next is some sort of tubes from behind the dashboard for hot air into the car, at least that's what it looks like. The 4th thing is the J pipe off the turbo, 14B, 16G, 20G. And the last one looks like the intake manifold supporting bracket. Why do you ask?
1 is the factory radio brackets, 2 the thing on the right looks like the piece that bolts to the head for a heater hose ( I may be wrong on that) 3 These are the side pieces for a 1g center console and 4. is a J pipe off of a 14b, and 5 is The intake support bracket thas ties the intake to the block in the back of the motor. Now can I ask how you got all these parts you dont know what they are :)
Good question, and sorry for the pic #3. As #2 it's definatelly a lower part of the thermostat housing, where the thermostat itself sits, and the one that bolts to the head. Belive me on this one, I had been there lately.
1- 1g factory radio mounting brackets
2- thermostat housing for a 1g turbo
3- carpeted panels to go between the front of the console and firewall for a 1g
4- stock turbo outlet pipe for for a 1g turbo
5- intake manifold stay/brace for a ?. Either missing vacuum crossover lines or for something other than a 4g63. Just at a quick glance and judging by the length, it looks like it was removed from a 4g37(1g 1.8 sohc).
