Resolved Help .. Idle surge
T Series Boost
4
Jul 31, 2010
Edmonton, AB, Canada
yup, I read some troubleshooting tips and no help. here's the problem
Symptom : Only when it's warm/hot out, and the car has been running for a while, the idle will start to creap up. When it really gets warm the idle will go up to about 1500rpm, and then drop to 900, and back up. in roughly a 3 second cycle. Makes ppl think I wanna race them.
I've disconnected the Idle speed control motor and it (surprisingly) was not the cause. I'm leaning towards the throttle position sensor, but before I get a new one, has anyone ran into this before??
any help appreciated.. the warm weather is just around the corner.
Solution
It was a three part problem. My front O2 sensor wasnt working right, I had my throttle cable adjusted too tight, and when the engine got warm the cable got tighter (yes, the opposite of what I would expect) and it was opening the throttle. My MAF honeycomb mod was a bad idea and probably contributed.
vacuum leak came out ok.. it's leaking a but around the throttle valve.. I dont think enought to cause this, but maybe when it gets really warm it gets worse. and I was following terry's troubleshooting, but it doesnt really seem like my issue. I will try cleaning out the EGR.. a good idea regardless.
A vacuum leak test is different than a boost leak test. Pressurize your intake tract to at least 20 psi and any leak is a bad leak that needs fixed as all air in the system is metered.
Personally I removed all my emissions and that cleared up my idle surge Im not saying it will help u but it does clean engine bay and less vac lines to worry about delete that egr.
Solution
