2G Help identifying these plugs
tunernewb92
342
74
Sep 10, 2008
North Canton, Ohio
I have three plugs that I cannot figure out where they go. I took my dash out about three months ago and took pictures of everything attached but somehow I missed these. Any help would be appreciative.
The first is drivers side coming off the dash. The wires are wrapped in foam. It comes out of the lower hole where the black plug is that plugs into the fuse box upper right.
The next two look the same. They are on the harness about two feet after it comes into the passenger compartment right before it comes up under the radio.
Can you read the connector numbers on them?
The first pic looks like your power mirror switch connector
