help complete my build
evil tsi
241
Feb 26, 2011
findlay, Ohio
I posted a while back a starter list to finish my build, now its time to order the parts and want to sure i have 100% everything. The only parts i wont be buying are the kiggly 6 bolt in a 2g adapter kit and the oem front case and gears(just because right there is $650). Heres my list please add what im missing(if anything) thanks for your help. the motor is assembled from the head down with the timing gears on(minus pan and front of engine)
oem exhaust manifold stud/ nut kit
oem intake manifold bolt kit
oem rear main seal bolt kit
oem water pump bolt kit(already have new pump)
oem aluminum half moon gasket
oem cas o ring
oem crankshaft sprocket flange
oem oil pump bolt kit
oem balance shaft gear eliminator
oem valve cover bolt kit
oem timing belt kit w/o balance shafts
oem castle plug and o ring
oem recirculation bov tube(using 1g bov)
oem map sensor bolts
set of ngk plugs(have ngk plug wires)
1g to 2g bov adapter flange
jmf map sensor adapter
map sensor
oem timing cover bolts
oem oil pan bolts
oem timing tensioner bolts
10an drain feed fitting(have 10an fitting welded to pan and have drain line)
oil feed from the head
already have the timing cover and turbo bolts. im also using the gaskets from an itm gasket set. please let me know if im missing anything
