HELP! Can't find correct haft shaft.....?
Purex2c
Dec 9, 2010
Missoula, Montana
I have a odd ball tranny, and can't find a interchangeable cv-shaft to fit. Front passenger side in a 95' AWD with a JDM swap. Transmission is a-
W5M332-WPWE
SH1110
Don't know what the bottom number's are for? But far as I could find it's from a Galant or a Lancer not offered in the US at the time.
Anyone help with a suitable interchange, or suggestions?
W5M33-2-WPWE is from a Evo II GSR with Viscous Front LSD and the 3.909 ratio, I have torn down two of these trannies and have full pics of everthing including the shaft (which is 75.25mm from the tip to the begining of the seal shoulder). Because of the LSD diff the front shafts are different from a normal DSM, the final drive is different as well. I actually had the shafts with my tranny but because of fittment issues with the EVO II GSR LSD and the DSM ring gear I ended up using a Quaife front diff. You could also just use a standard DSM Front diff with ring and drive gear set and be fine. Bottom line, I think you will need more than just this shaft unless you are running the 3.909 ratio in your car, either way here is the part number for the inboard half of the right side shaft MR166160.
i am also wondering if my rear ratio matches the final in the front.. what numbers do i look for on the rear to check the ratio...
