Help before Purchase please Urgent!
darkstardevil26
Jul 14, 2010
chesterfield, Vermont
Okay I've been looking around VA area to find a gsx to purchase and i finally found one. Have a few questions on what ya'll think I should do. The guy who owns it now got it stock from original owner it's a 95 GSX. He ended up doing full greddy 3" IC piping and upgrading to a big 16g turbo also getting a recirculating BOV. got an ugly body kit ugh :( only bad part). The transmission though doesn't seem to want to go into gear at times liek when u put it in the clutch out to gas it wants to grind and pop out ive been told it's most likely the transfer case or syncro's. The guy is selling the car for about 3200 and the set up alone would be worth that with all the extra's it comes with as well. I just don't want ot buy something then have hard to fidn parts. So any issues you guys think can't be handled by someone mechanically inclined or should i not bother to mess with it. Liek how hard is finding a rebuild tranny kit if nota refurbished tranny and transfer case and some $'s on how much they'd cost. The car is pushn 22psi and makn around 350hp i beleive. Please help asap i dont want to miss out on this good of a deal if it really is a steal but if think all im going to get is problems ill just sit back and wait once again motor has 116k on it so ill do maintence asap. Also any good places to buy factory bumpers for cheap? thanks in advance ### respond asap. if something isnt clear say so and ill try and make it worded better.
big 16g turbo stock manifold i beleive full greddy IC3" tubing 3" turbo-back exhaust, ground effects kit :( (will be replaced after maintenence), 7" LCD touch screen head unit, tri-pod a pillar gauges are air/fuel, boost, and oil pressure. umm halo headlights. full ground control coil overs. re-circulating BOV. i think it has a manual boost control dont ask how im not 100% sure didnt really get to look at it a ton today was in a rush.
Leather? Has the timing belt been done? Its coming up soon if it was properly maintained before. Do you know if its a real mhi big 16g? What fuel mods? SAFC I hope and 550 -650s on that kind of boost.
Sorry I just seen how much he wants in the first post and the miles, its kinda hard to read with out capitals and punctuation but I will leave that up the the grammar police.
I'm going to get full details tomorrow, so please check whenever possible. thanks for the fast posts all means a lot hopefully part of your community soon this has been my dream car for a while. Sorry about the typing as well was in a hurry I'll do better now, I know what the grammar police are like from the prelude forums.
He's going to show me all the receipts so from that i'll be able to see the whole build, but what cc are stock injectors, cause he said he kept stock fuel rail and same injectors but also upgraded to a 255 walbro fuel pump.
is the gsx a 21,21,23 spline transmission? fora 95
All 2gs are 23. You can use any 2g trans but if you get a 95-96 trans you need a 95-96 T case and if you get a 97-99 trans you need a 97-99 t-case. Stay away from the jdm ones they have a differnt final drive ratio and wont work with the 2g rear diff unless you swap some gears.
