ECMlink Help! 1G car wont start
BichoteAWD
40
Oct 28, 2010
Boosted, Florida
Bought this 1g a few months ago with DSMLink light. set for 2g MAF, E316G turbo and 650cc inj.
Now car has 2g MAF, 20g turbo, and 1000cc injectors.
I put everything together motor cranks, got spark. Got fuel pressure 45psi.
But not starting. It is still set for the 650 at the moment.
Will the size difference in injectors keep it from firing? Or should it still turn on just run richer or leaner? please help asap thank you
If it is still set for 650 why dont you put the 650s in or change it to 1000? Did you play with anything else either timing, stuff that could possibly effect it?
Going from 650's to 1000's is a pretty good size jump so that is most likely your problem. With the 1000's running on the 650's tune you're spraying way too much fuel. Pull your plugs after attempting to start and I bet they're wet with fuel. You need compensate for the 1000's.
Yeah man, if you have DSMLink V3 Lite just calculate the correct settings for the larger injectors. It is extremely simple.
Your are flooding the motor with all the extra fuel going into the cylinders. Thats a 350cc difference dude(huge) .
