Heelp!
Blam
186
May 26, 2003
Edmonton,
whenever I pop my car into neutral from 1500+ rpm it drops straight down to 0 and stalls or drops to 500-600 and revs back up. if I slowly stop from 1000-1500 and let off it will be ok.
the car itself idles fine at 750 give or take 100.
I tried fooling with the BISS and that didnt help.
I cannot find any vacuum leaks.
I am recirculating my stocker BOV
fuel filter was changed not too long ago
air filter is clean
brand new BPR7ES plugs gapped to 0.028...old ones -> http://members.shaw.ca/blamo/plugs.jpg
ISC reads proper resistance
TPS reads proper as well.
TB is cleaned.
new intake mani & TB gasket.
HELP!!!! I'm gonna go crazy!
thanks
PS: does the cold weather have nayhting to do with this? I had no problems last year...
good chance. my car does some funny shit when its cold. try replacing your isc.
oh, I was told it might be my fuel pump dying and not being able to deliver when I step off the throttle. how do I test it?
Im not sure how to "test" the EGR, I just removed mine, and it seems to run a lot smoother.....I guess mine was leaking.
Anyways, it takes the same amount of time to remove it as it does to change it or test it ;) And the EGR is just more emissions crap that you dont need.
http://www.vfaq.com/index-main.html
They show you how to do it there, its pretty easy.
Good Luck:thumb:
"remove" it or block it off? I will give this a try as soon as I can get my hands on a block off plate. in the mean time, any other suggestions?
you can put a volt meter on it..if its low, id get a walboro 190, or at least rewire the pump....or both.
Well, ya, you just block it off... Too much Guinness, sorry.
Just go to Canadian Tire and buy a peice of sheetmetal, and make a plate.
Also, look into the FP like Phil mentioned.
thanks guys, I will look into the FP tonight if I can. and I will grab a EGR block off as sooon as I can as well.
  • Wanted 6 bolt NT water pipe
    • chrisman287
