head question
kinter86
Feb 19, 2008
cortland, New York
I seen on 2gnt that you can swap 4g63 valve spring into the 420a. So, i was wondering if I upgrade the springs to the 4g63, 2.7l pt crusier lifters and rocker, and ss standard size valves, new seal, how much hp or boost do you think it could handle.
The same as before. 2.7 rockers have updated oiling as do PT lifters, 4g63 springs have a higher spring rate, and SS valves won't make anymore power than inconel or any other valve material.
I believe Bullett was revving over 7k with a larger camshaft and factory springs. Shouldn't be a problem at all with 4g63 springs and factory cams, within reason.
Probably closer to ~6800.
That is a good point, though, Nemezis. With a factory head (cams, valve size, porting) and being naturally aspirated, there isn't really any benefit in spinning the engine faster than it is already able to.
o.k. so ill check out some larger cams, thanks for the input guys.
