Head Lights and Parking Brake Light
SwiftSES
Jul 22, 2005
Yonkers, New York
#1 My headlights stopped popping up out of the blue.
What could the problem be?
and #2 My Parking Brake light stays on after the parking brake is down and depressed.
How could i fix this?
:dsm:
1. The parking brake light is probably just low brake fluid. Just check your brake master cylinder to see if it is at the right level.
2. The lights not popping up could be a number of things, you are going to need to get a wiring diagram and go through all the connections. Just make sure they aren't loose.(my talons lights didn't pop-up when i forgot to reconnect the pop-up switch on the dash. Although if i manually put them up they would go down on their own) If the connections aren't loose then you will need to check if the wiring and the components are good. If you don't know how to do that I'm afraid you may have to take it to a dealer(sorry).
