Head good\bad
zachdeagle16
97
Nov 17, 2004
coosada, Alabama
I have a head that im thinking about putting on my car, what are some things that i should look for to tell if it is good or not.
:talon:
check for deck warpage, check the valves ...see if there burned or bent, check lifters ...see if they might have seized, check the valve seat, and if its a used head probably a good idea to replace the valve seals
I concur. If you are unable to discern what is good or bad, take it to a good machine shop and get their professional advice. May save you money and rolaids later. Good Luck
