98spydert
- 1,916
- 9
- Jan 16, 2004
Phoenix,
Arizona
www.dsmparts.com is one choice.
painmaster said:So wheres the best place to buy stock Mitsu parts like the composite gasket now?
NOSLO2PT0 said:Mitsu Metal gasket MD349347
Rob Rohr said:What did Mitsu originally intend this gasket to be used for? Was it a factory rally part or stock HG on one of the early EVO cars?
The DSMparts.com website says "4 Layer Genuine Mitsubishi/Ralli Art Headgasket. This metal 4 layer metal headgasket is almost twice as thick as the stock unit." If it is so thick I wonder what effect it has on the C/R?
its thicker because its designed so you don't have to use a shim after you mill your head before installing the new gasket.Rob Rohr said:What did Mitsu originally intend this gasket to be used for? Was it a factory rally part or stock HG on one of the early EVO cars?
Turbo Talon DL said:Im getting a mitsu 4 layer HG with NEW stock head bolts, is it absolutely necessary to use copper spray? And also, my head has been milled, but im not so sure how milled my block is. Im having wiseco 9:1 pistons installed. If I use this gasket with minnimal milling on this block, how will it affect my compression?
My builder said he's setting the "torque plate to 72lb/ft" whatever a "torque plate" is
Turbo Talon DL said:my block's already been built for stock bolts....im not going overkill on the boost or anything....yetMy builder said he's setting the "torque plate to 72lb/ft" whatever a "torque plate" is
Turbo Talon DL said:Stock torque is 72lb/ft for stock bolts. Whats wrong with how he's building my block up? Oh, BTW Suparata is the one building up my block and he says that stock head bolts are fine for my application, which wont exceed 400hpI just wanted to know if i NEEDED to use the copper spray stuff.. Im hearing horror stories about it and want to avoid timely mistakes if I can.
