head flow with SBR G50'trim
liquordrunk
552
13
Nov 12, 2004
Va Beach, Virginia
i have a stock block and im goin with a SBR G50trim and with a stage III prted head and magnus intake and EVO mani ported i should get better FLOW so that in which would mean that my turbo would spool faster correct?? if so that would mean i could go with SBR60-1 on a stock block with hks 264/272cams and should have reasonable spooltime around 3600 correct ? guesstimate?
thanks for any input
Headwork and cams will actually make your turbo spool slower. You'll flow more air, but you will have less velocity. The flipside is that you will make a LOT more power with your headwork and the cams.
You will spool slower though, don't doubt that.
