Jacolu3
- 638
- 131
- Jan 31, 2015
Lake Grove,
New York
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
no boost leaks and a small leak on the flex pipe on the dp
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil:stockl coils
Wire brand and Age:ngk brand new
Spark Plug brand, type and Gap:ngk 8s .28
5). Motor health (Compression Test)
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments?
Idle Switch:yes
Throttle Cable:tight
TPS:.63
BISS:errratic
7). Compression ratio
9.5:1
8). Any known bad sensors or brittle wiring?
no
9). Any DTC/CEL codes?
no
10). Electrical system
Car off (not running):good
Car running:good
11). Base fuel pressure and injector values
Base Fuel Pressure:43
Injector Size (cc/min):fic 1120
12). Properly calibrated and configured wideband sensor
Sensor Brand:innovate
Calibration Date:3 months ago
13). Type of fuel
Type:93 octance
Percent of Ethanol:
14). Watched ECMlink how-to videos?
many times
So the car seems to be running good but I cant for the life of me get my ISC within the 30 range and get the airflowperrev anywhere close to 25
I am running DKS 280 cams so ive tried with an idle of 1000 and 950 and I think it runs better with an idle of 1000.
Ive tried turning the biss screw to get the ISC to the 30 range but it will drop down then slowly raise up again. If I turn it too much the car wants to die and thats when I turn it back up. My idle is pretty decent and my fuel trims are in check, but I cant seem to find the happy point for the ISC.
I also pulled the plug on the ISC to check the ohms from 1-2, 2-3, 3-4, 5-6 and they all were within spec
Also ive tried to log the airflowperrev in the sd ve table and drop the cell 20 points and it lowers it a little bit but then idles really bad and the fuel trims are in the 20% instead of 1-5%. But even with that drop in the cell its still in the 40 range for the AFPR.
Any advice would be greatly appreciated.
Thanks
Brian
yes
yes
4). Ignition system
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Idle Switch:yes
TPS:.63
BISS:errratic
9.5:1
no
no
Car running:good
13). Type of fuel
Type:93 octance
Percent of Ethanol:
many times
Thanks
Brian
