Has anyone used one of these or heard any reviews on this?
bluelsr90
95
3
Aug 3, 2005
petersburg, Virginia
Looking for away to hook up a mbc without tapping into my turbo. My j pipe doesnt have the nipple so I was going to drill and tap there but ran across this FTG-QuickTap-CompHSG from atpturbo.com. I was wondering if anyone has one or has heard any reviews on this item.
I know this doesn't answer your question, but might give you another option if you're interested.
I prefer to use a source at the IM since that's what the actual boost pressure is going into the motor. There can be a noticeable difference between the boost coming out of the turbo and whats at the IM based on turbo & FMIC efficiency, boost leaks, etc. I want a stable boost at my manifold not the compressor housing. However, its probably safer and less likely to over-boost right at the compressor if you have a large boost leak...
However, it does look simple to install and seems like a quick solution to your problem.
