hard start, rough idle, dies in drive, but not in reverse? HELP!!!
imler202
Nov 27, 2012
altoona, Pennsylvania
I have an 95 eclipse gs 158xxx, its just a stock 420a with a cone filter( from what i know) i just traded my 96 geo tracker for this car. when i test drove it it ran great hauled, did 125 up the mountain, gas light came on, i got gas. ran fine, went 125 miles, filled up again but this time it started running funky( missing, spits really bad) when touching the gas rpms go from 1500 to 3000 to 2500, bounces really bad. It's hard to start i have to pump the gas to get it running. it sometimes idles right on 1k but sometimes its at 400 and ready to die. I put it in gear an it dies. i put it in reverse though an it still runs, thats what i don't get. Any ideas? i'm new to dsm's an would like some ideas. Let me know thanks! This is my only car right now, an my code reader is for 96+
It is throwing a cel, but my reader only works on 96+ :( and the plugs,wires,and dist are all good. the fuel pump is also working. I was thinking maybe a filter?
I can't get it to the store, and the filter is good. I'd like to get a new fuel filter, I need to get to autozone to get it. so i have to wait for a ride
The code reader should work. Isn't it still OBD2 on 95s?
I'm guessing its an auto as well?
That's where it was on the non turbo I almost bought. Hunt around for it if you can't find it. If you previous owner was THAT jank to remove it, goodness....
Yeah, its there it was just tucked up in a bit more than expected. thanks. i'm going to grab the reader tommorrow. ill let you know the code/codes
Found the problem, after tinkering under the hood. I bumped the egr valve an the motor died, so i clean it up cleaned all the hoses an it runs like a champ agaiin
