Ha haaa thought I was done...
Thrasher101
Jan 2, 2010
Auburn, Washington
So I changed out my heater core this week in my 97 GS, and after a rough battle and everything is back together my wipers front and back do not work. They worked prior to the dash tear down so my question is what did I not hook back up? I followed the wiring today from the steering column back to the main wiring harness under the dash but everything looked fine. Can someone help by locating all plugs under the dash that involve the wipers minus the switch by the cabin vents for the rear wipers and the plugs on the steering wheel itself, they are all fine. Also does anyone have a picture of the interior fuse box cover label, it would be greatly appreciated. Thanks everyone
one more thing I have two loose plugs coming out of the main wiring harness (coming out right next to each other) to the right of the steering wheel right behind the upper left bolt that holds on the lower trim peice. They only have 3 inches of slack so whatever plugs into them should be right there... one is clear whitish and the other is black. Any ideas if they are for add ons or dummy plugs or they have to do with my wiper problem? Thanks again
ah, i dont have any pictures right now but im pretty sure you might of moved out of connection a relay, check and adjust all your relays and see if that works.
something that would be cool to have even if this forum is here for this, you should buy a haynes repair manual, sometimes it helps sometimes it doesnt, i dunno im just trying to help
try looking at a electrical diagram. might be one right in your cars manual. otherwise search the forums as i have seen them floating around
