guides for 4g64 swapping 1g head
97GS-TSpyder
3,589
5
Nov 13, 2002
yokota AB Japan, Asia
i have a few walkthroughs just making sure i know what im getting into when i go do it...
but im looking for walkthroughs on the 2g 4g64 motor, doin a 1g 4g63 head swap....any help woudl be greatly appreciated
and for those that did it, whad did you use to fill in the passageways you had to fill?
yeah i found a few toutorials on a few sites but i jsut wnat to get as many as possible, doesnt relaly seem too bad but thanks for the help
actually all you need is the pistons and crank and some other shit, its the same block im pretty sure, correct me if im wrong
4g64 is no the same as the 4g63. its got a taller deck height. also there are a few holes in the deck that need to be sealed to mate the head to it successfully. the head lines up with the edge of the block but the deck has a few differences.
close the holes,drop the head on it with 64 cam gears and your good. but its not that easy at all. just read through that thread and youll get enough info
