Gst Leather Seats on a Rs Eclipse
intimidator2000
166
Sep 16, 2004
O, Florida
I will soon be receiving two stock 1999 gst leather seats and I wanted to know if they can fit on a 1999 Rs Eclipse.
The plug is under the factory seat you may have to dig under the carpet to find it. As far as bolting up they are direct bolt on.
1993eclipseGS said:
Yes. It would have been more expensive and they would have lost money in the production of the cars, If they were to stop every ''lower model'' car and have them without all the power accessories hookups.
yup when i put leather seats out of a gsx into my n/t it was all just plug and play.
I don't think his seats will be power anyway because they are out of a GS-T.
intimidator2000 said:
The person I am getting it from he told there is no electrical just bolt it in thats it.
ya then you should have no problems what so ever, its sort of a PITA getting the manual seat tracks to line up right and then stay in place perfect while you put the seat in but other than that it should only take a couple minutes its only four bolts.
i have a 96 rs and i took leatehr seats out of a talon and put them in my car. to my knowledge there is no hookup maybe im blind or maybe the talon connecter from the seat is diff from eclipse model. maybe that would explains why i didnt notice it? so my car has power seats for about a year and they dont work. any suggestions ideas?
does 96 rs have the wires there?
The wires are there in all 2G's, one for power seats, one for the seatbelt light i believe. They are tucked under a slit in the carpet in the middle under the seat.
I just tried to hook up power seats in my car and when I hooked it to the wire under the carpet nothing happend. Is there maybe a fuse that needs replaced and if so then what one?
I was always wondering what exactly those disconnected plugs underneath my seats were for ROFL Figured it was something for heated or motorized seats.
Check your fuse box, there very well could be a missing fuse since the seats did not come power. Or maybe you are hooking them into the seatbelt spot.
i could never find the cable for the seats. i took my seats out of a talon maybe they have different connectors. i looked all around the dirver side even took up most the carpet all i found was some condoms from the previous owner haha... not a bad spot to keep them i guess
Sorry for bringing up an old thread but I just put power leather seats in my 97 Spyder GS and I can't find the power connector under the carpet. I peeled back quite a bit of the carpet and I don't see it. Should it be on the same part of the wiring harness as the seat buckle sensor?
it proly rolled away or something, take the carpet out and find it.
