ground controls
ClipseTurbo
36
May 27, 2003
hey guys, i installed the ground control coils on my gst, and the back coils dropped perfectly. now the problem is the front coils actually got highr instead of lower. i checked my steps, and veerything was fine, and i don't understand why this is. any one know why?
yes dude, i have lowered them to the max. does any 1 know the correct coil# that ground control uses? i checked the website, but they dun show part number. other than that, i dun know what else to do.
: x
Just checking :p
Pull off one of the front coils and find out the hight of it. I think its 7" that is suppose to be used on our cars, but I forget. Im you could find it searching. But if its like 8 or longer then that might be why.
-Dallas J
this same thing happened to me when i installed my springs but thats because i got 8" springs in the front (on purpose) for more front suspension travel. After they a couple days the front settled in nicely to a good ride height.
problem solved... i called up gc and they told me to chop up my gr2's so i said screw it and ordered agx's. problem was gr2 was causing coil to be higher than usual. the coil would usually sit on the stock boot, but it wasn't.
bj
