ground controls..do i need camber kits?
Yes and No. Yes if you want your car aligned correctly or if your setting the car up to be predictable / have good tire wear. No if you don't care and just want your car lowered.
Yes, you'll need an alignment otherwise the toe you gained with the camber, resulting from the drop, will destroy your tires. What shocks are you going to be using with the ground controls? Stock ones will explode, and anything but Koni's will be a terrible ride, nevermind the spring rates being far too radical for most Japanese types of shocks.
yes i got koni's. i got pro kit to on the rear and ground control on the front ,i got pro kit and for the front but i am waiting for my spring perch becouse i bouth the front koni's used and they was with groun control . and i put them on and i like the front to be more lower. i am still thinking to go with pro kit on the front or to stay with the ground control but i don't want to destroy my front tires becouse they are new and expensive.that why ask do i need camber kit for the front or i will be ok just with aligment. I know you don't need camber with pro kit
