Greddy Turbo Timer Error Message
ApexVIII
812
5
Jan 12, 2008
Modesto, California
well my car died so i jumped it, and now my Greddy turbo timer is reading some kind of a message, it lights up, and it looks like of like a back wards C then a O the a 5 so like C05
any ideas? maybe when i jumped it, it fried the TT?
EDit: actually it reads out something like a E05 (or E0S)\
here is a picture
I would just unplug it and try to set up your time you had before and see what it does. maybe it just needs to be reset.
yea i tryed unpluging it. i can only turn it on and off(it only light up and shows the message does not keep the car running)
LOL when i got home i shut the car off, it showed the E0S message and the car was still running, i let it run for like 30sec befor i started taking the dash appart to get to the pulg to unplug it so the car would shut off.
Not much help here but I have the same problem with this greddy TT for the last 2 or so months. Its been on and off of the car uninstalled and when I put it back, it reads the same thing. It never counts down. my error code is 3 backwards ''C'' or ] ] ]
I would also like to know how to fix this.
i have seen other people having the same problems...
no bumping allowed
as for your problem unplug the timer for a few minutes then try pressing the power, select,time buttons all at the same time to see if it responds
asking if no body has this similar problem is not really bumping....
anyways i googled it and other people have gas similar problems but no one knows how to fix it
maybe it cant be fixed :(
and now the greddy is going belly up LOL i think im screwed
here is a picture
Disconnect, plug back in, and try pressing the p and s button or the p and t buttons to change the settings.
Edit: Here's a manual for you :)
http://www.greddy.com/img/PHP/products/pdf/685.pdf
Edit again.
If you look at the harness of the turbo timer it should go to its own little 4 wire black plug (this comes with the timer out of the box). The other end goes to your ignition barrel. Anyway undo that plug and you'll have the 4 prongs. Use a test light or even better a multimeter and test that you have the correct power going to each one. One should be constant 12volts, the other igntion power, the other is accesories power and the last is negative.
The negative is black, the red is constant, and the green and blue are accessories and igntion. Not too sure which ones are which
That's all the information I can give you. Best of luck.
here is a picture
Yes asking people if they have similar problems isn't bumping, but doing it over and over and saying things like " to the top" is.
damn i get all these noobs trynig to pwn me.
LOL
but yes i have tryed upluging it and pushing all the buttons the only button that will respond is the power button.
i guess its time to crack it open and see if anything on the board is messed up
internal ERROR ,in your case you got to send it back to Greddy,and have them fix that error,or your best bet would be get a proven turbotimer like HKS.I had problems with my 4 greddy turbotimers.finally i bought a HKS and im happy ,that i did that ;) Greddy electronics are JUNK.
ooo i see is that what you got also the same message?
the TT came with the car so i did not buy it.
i guess that greddy is bankrupt not much i can do LOL
I have had problems with this tt, that code did pop up in the middle of my deal.
mine was starting to count up very very fast, and was killing my battery. after unpluging it and putting it back in, that code poped up, but went away after unplugging again.
after putting it back in, it still counts up as fast as it can, but won't keep the car on when u turn off the key. I have tried sooo much, pressed very combo of buttons, rewired, and even kept it off for over a week and reinstalling, but nothing...
Oh man, I recently bought one from craigs list the other day and this same error came up when I finally hooked it up LOL. He claimed it was working and was originally selling it for $35 but I got it bumped down for $5 so it's not much of a loss.
( he doesn't answer my calls and his line was suddenly d/c'ed )
I have the same issue. I Jump started my car and there's the error, the car will continue to run, I had to pull the motor fuse to kill the engine. I'm going to take it out this weekend and test it with the Multimeter. I will probably rip it open as well to see if anything has been fried on the circuit board.
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
