Greddy TT problem's
Wildman95GS-T
147
Aug 6, 2005
Dothan, Alabama
I did a search and could not find an answer to my problem, my battery went dead today and after replacing it my timer had reset itself. Everything seams to work, but when i tried to set the countdown timer, it does not turn my car off, i had it set for 1'30" and displaying battery voltage. I cannot get it setup that way again :confused:
I have the same one and one time my battery died and it was all messed up after i just unplugged everything and plugged it back in and it worked fine, kinda weird but o well its worth a shot?
I've ran into this issue before, on the back of your turbo timer there should be a little switch on side is labeled IG and the other one is labeled ACC. For your car to shut off with the turbo timer it should be on
ACC also i believe. I have included the link for the greedy turbo timer manual, the answer to your problem should be on page 26 of the PDF file. http://greddy.com/img/PHP/products/pdf/685.pdf
Yea, i was scratchin my head when i installed mine too, ### all my instructions came in japanese, so I ended up having to pull it up on greddy's website. I really have no complaints about the turbo timer, but they could've just added another button so you can scroll through the options a little easier, that's really the only complaint I have with this turbo timer, other than that, it works flawlessly.
Yea i like mine too, as far as the other options it gives tho like quarter mile time and stuff how do i hook all that up? i basically did a quick easy install and it is just doing the turbo timing right now. Basically how do i get the other funtions to work properly?
You have to hook up the speed sensor wire to probably a pinout to the ecu, u can look it up on vfaq i believe.
no, there should be already a wire for that off the turbo timer. I believe it's purple, but don't quote me on it.
