greddy emanage utltimate question
torque77
31
Jul 6, 2005
kingman, Arizona
so im tuning my 99 eclipse with the greddy emanage ultimate, now i just hooked it up this week and we went to go and tune on it but my timing isnt reading right. it is really low when the car is at idle. i have 650cc injectors in with a 50 trim and a built engine. cams are fp2s. anyone know why this would be. if you rev the engine when you get to about 2500 the car will start to studder and wont go above and yes the rev limiter is set at 7500 so its not that. any help would be appreciated.
when I was using a SAFC and MAFT combo a freind of ine thought the knobs on the Maft were cool so he accidently turned one? when I started the car, it was idling very irradic and was about to die and when I attempted to give it some gas it did about the same thing as yours. Thing is I can not remember if it was too low or to much fuel, but I want to belive it was to much. Just double check your settings.
One other thing. was the car running great just before this happened or did it do this just after install of the first setup? If this is a inital turn on then double check everything connections, and all. Its amazing what you accidently over look when trying to finish up.
